Saltar al contenido principal
Can't remove Logic board from the iPhone 5?
I removed all the screws and the iPhone's motherboard is stuck and won't budge, i even removed the sim card tray, still no luck, this is the third phone i've had and don't know how to remove this stiff logic board
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
If the SIM tray is out, then you have missed a screw. It will come out easily once all the screws are out----make sure you're not forgetting the 2 screws at the top case securing the antenna
Fue útil esta respuesta?
Puntuación 1
6 comentarios:
I got those two out already
- de
Let us know which one you missed when you figure it out. Logic board slides out no problem if all screws are out.
- de
I pried on the board trying to lift it and it snapped from area where a screw was already removed, I guess the board was old
- de
"pried on the board" ouch. well give me a call when you need a pry damage fix.
- de
Where the battery has the latch that connects to the board .. We'll that part of the board is ripped , just that a tiny piece is it fixable by buying a bare board
- de
Mostrar 1 comentario más
There are two screws one either side of the simtray left and right..
Or post a pic that would be great and we can point it out
Puntuación 0
4 comentarios:
Pryed on the board were you left a screw in you mean logic boards don't stick when all screws are out
- de
It did stick, don't assume because I can clearly see the board didn't have a screw there, if you disagree then don't comment!
- de
Don't disagree just find it very weird
- de
Hello nick email Jessabethany@gmail.com and post her pics of the damage and she will hopefully be fit to help..
There is a screw under the interconnect cables hard til see but the cables need removed to get at that screw. It's in that position you described
- de
Añadir tu respuesta
Nick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 600
