Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
Preguntas 3236 Ver todo
Why does my iPhone charger only have red, green, and white?
So my iPhone charger cable was broken, and i attempted to fix it myself. I opened the case and found the little green platform (don't know what does are called) which has label of W, G, R, and B. I figured those stand for White, Green, Red, and Black. However, when i cut open the wire from the middle, I found only 3 wires. Red, White, and Green. Since I also wanted my charger to be charge only, I searched online and figured that I only need the red and black cabled. BUT I CAN'T FIND THE BLACK CABLE ITSELF! Other than the red, green, and white, I also found 4 bunches of ultra thin wire grouped together. Are those the black cable's inside?
Can anyone tell me how to plug/tape the wires into the green platform so my iPhone would charge?
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Alex, interesting little project. How about you post some images of the circuit board (green platform) and your cable and let us see what you see. Use this guide Adding images to an existing question to add images.
por
Agregar un comentario
6 Respuestas
Respuesta Más Útil
buy a new charger Save you any bother
Fue útil esta respuesta?
Calificación 2
TL-DR: Don't be cheap, buy another cable and even better get one that is good quality
Calificación 2
Alright bro if your really trying to do this and just want it to charge you just need the black and red wire. If you want it to exchange data or download something off a different device your going to need the white which is the positive data wire while the green is the negative data wire and those above which I listed(black,red). Just make sure you connect those wires to the correct corresponding mounts or you'll short your it out
Calificación 0
Comentarios:
Just make a ground if you can't find it
por
The extra thin wires are the black wire with no insulation I had the same problem I just wrapped the part I didn't want striped with some electrical tape. Your welcome
Calificación 0
As above, there are three colored wires (Green, white and red) and additional unwrapped thin wires in the bundle. All of it is wrapped in foil, a braided sleeve and the rubber on the outside. If you're looking to power a device - you need the need the redish orange wire and the loose wires, the loose thin wires can be twisted into a cord and soldered in place. This info is useful you want to power a device if the connection (the female cable connection shorts) . . . I directly connected an LED light, for example. . .
Calificación 0
White is a data cable that is on positive volts .
Green is also a data cable but lives with the negative.
Red is hot.
You have a weaved wire that should be on the out side of the cluster of wires that is housed in plastic thus being your ground or 4th wire
Calificación 0
Añadir tu respuesta
Alex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 53
Últimos 7 Días: 348
Últimos 30 Días: 1,558
Todo El Tiempo: 10,991
