Saltar al contenido principal
Lanzado en junio de 2012 / Procesador Core i7 con Turbo Boost / Hasta 1 GB de RAM de video DDR5
Preguntas 596 Ver todo
Serial No. went missing on my MacBook Pro
Hey guys!
Have you ever met this?
I have been recently suffering from nVidia issues on my mid2012 i7 15" MBP. It freezes all the time, have little squares, and lines on screen, when frozen. It wouldn't be a problem, because I have Apple Care, BUT!
As far as I am experiencing these issues, my motherboard forgot it's serial no. It's like if I had already changed my logic board, it says "System Serial#".
I am working with Macs, I am repairing them since 2010, but I've never seen anything like this, and this machine's logic board hasn't been changed, that's for sure, bcz it's my own.
I attach some pictures, where you can see, that hardware monitor app recognizes that I have "switched" computer, but remembers an older machine (with my serial no.), which is quite similar.....
https://www.dropbox.com/sh/0xrdv6o3f700q...
Es esta una buena pregunta?
Puntuación 2
1 comentario
Would you mind giving us full serial number off the bottom of the machine.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Did you check the systems firmware? Here's Apples TN on how to check and update: EFI & SMC firmware updates for Intel-based Macs
What happens when you boot the system off of an external HD or thumb drive which you know works correctly on a different like system? Does it still mess up?
Fue útil esta respuesta?
Puntuación 1
Will this solution work on a Mid 2013 MacBook Air 11”?
Puntuación 0
1 comentario:
Time marches on!
This solution was workable with the older OS-X OS's. I'm sure you are now using a much newer version of OS (MacOS) I would recommend you give us all of your systems details in a fresh question here: Ask a Question
- de
Añadir tu respuesta
Andras estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 11,255
