Saltar al contenido principal
La consola de juegos Xbox de tercera generación de Microsoft, lanzada el 22 de noviembre de 2013.
Preguntas 727 Ver todo
My Xbox One's fan is making this weird noise
Hello iFixit!
This one issue I am having with my machine. It seems my fan is making this whirring noise, but it doesn't sound like it's physically grinding on anything, but something sounds off, some described it as simply a cheap fan making noise, but I am not sure...I know MS support is usually the best way to ask, but they have been unhelpful as I have went through 3 systems with the same exact issue; MS support keeps giveing mixed reponses between "that is normal" and "send it in".
Seeing how you guys are experts in technology, I said why not give it a shot and post this haha.
Anyway, I have found a video with the EXACT noise I am having (and apparently others also) https://www.youtube.com/watch?v=jQaBr_xI...
I would really appreciate ANY input; whether is it normal or not, and should I worry about it, etc.. Thank you so much in advance, and again, I am such a huge fan of you guys!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 10
12 comentarios
Is there a way to prevent my console from overheating because mine gets really hot.
- de
before anyone makes this mistake (NEVER PUT A DRINK ON TOP OF UR CONSOLE)
- de
Ethan Dyjak its normal to get hot if the top of the fan or console where the fan is is hot that is good it means its ventalating good its blowing the hot air out rather tahn keeping it in
- de
Can someone help me. Mine makes a very loud noise like something is getting scratched even when there is no game in it. on certain games if I look in a specific direction it stops. It's very annoying my family even complains about it.
- de
my fan just whirrs really loud and it even does it when it is off. help please. ive had to unplug it at this point because it just wont stop
- de
Mostrar 7 comentarios más
Agregar un comentario
9 Respuestas
Respuesta Más Útil
It's most likely the console's system fan. Since it seems to be a common problem, I wouldn't worry about it too much, but if you're really concerned, there is a course of action that you can take. The first thing that I would recommend is lubricating it with a mineral oil, don't use WD40 for this. You'll need to disassemble the console to the point where you have access to the top of the motherboard, such as step 10 of this guide. I can't tell from the pictures, but it looks like you can remove the plastic fan assembly from the heatsink. Do that, and then use this procedure to lubricate the system fan. That should quiet the fan down and possibly extend it's life.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
Actually upon some further inspection, I've found that you don't need to remove the fan from the heatsink. Just remove the black sticker on the top of the fan assembly and lubricate there.
- de
Thank you so much for the answer!
Since opening it will break warranty, and I'm really not that savvy with any machines, in your honest opinion, do you think if I leave it be as it is, would it cause any issues in the future?
I asked around my group of friends and they all have the noise, and I asked around forums and even after getting a new unit/or their unit repaired, they said it still had the noise; making it a very common issue.
But, anyway, thank you so much for answering, much appreciated!
- de
In your situation, I personally wouldn't worry about it. If the noise ever gets worse, then maybe it may be a good idea to look into repair. For the time being though, don't stress over it.
- de
Hi guys
My one has been doing this since out of the box. Progressively getting louder. Now my unit started ticking and it litterly went poof. Not a joke. So I'm sending mine away
Just a warning if it's getting worse back up what you can and be prepared for the worst.
Puntuación 2
5 comentarios:
Did it make a wears nois mine did and I discontent it I am anly 10
- de
Mine makes either a ticking noise non stop or it makes a noise of the fan but my Xbox is off
- de
i think its the hard drive or something like that. thats what my dad said he thinks.
- de
mine does the second part of corey cooks response.
- de
Yes mine too and I am also 10 but I hit mine@xbox360
- de
something to try is turn the console off, then check all point of the power cable. blow dry then hover the vents on the power brick to remove all the dust. worked for me. just try and keep the brick well ventilated. also try blow drying and hovering the console just to be safe
Puntuación 2
I had this same noise. So I gently tapped in the middle of the fan vent and it stopped clicking.
Puntuación 2
My sons Xbox kept making this weird noise while he was playing it was driving me mad someone said it was dust on the fan so while he was out I cleaned it I got the hoover and hoovered any where I could see that there was and vent leading inside the Xbox and it worked for a short while so now every time I hoover up I go over the Xbox and since I’ve been doing that no whistling thank god because it was driving me mad
Puntuación 1
I fixed mine (so far at least) by taking canned air and blowing out all of the built-up dust on the heat sync. I would also recommend doing this to the power supply and the kinect if you have one. But make sure the Xbox is turned off, doesn't matter how from what I've found, it's just the fan can’t already be spinning.
Puntuación 1
Bearing probably gone OR you have a huge build up of dust in it
If you take it out and you can feel movement on the shaft laterally it's probably worn bearing
Puntuación 1
I know what to do basicly you got to contact Microsoft and tell them to send a Xbox one shipping for free because your Xbox has a broke disc drive and it can't be solved by yourself and there is no way you can fix it that you have looked for forms to help you with it and it doesn't work pls help " say that and they should send you a Xbox shipping free in your mail so u can play Xbox again! It worked for me . Hopefully I helped you bro sorry you have to pass through that!
Puntuación 0
DO NOT send it in. (Unless you don’t know what your doing, in that case send it to a reputable shop.)
Very simple yet complex fix, take the console apart, order replacement fan, (Unless once again, you know what your doing and can splice/ and or tap in to wires, which I replaced mine with a Noctua NF-12 Redux 1700. Works great.) order a OEM fan from Amazon. Replace it. You’ll have to remove the Hard Drive (In this case WD Blue 1 Terabyte) from its place. After removing it should expose the 4 pin connector. Remove the fan by moving the clips, and then lift the fan from its long time resting place. Clip the other one on, connect it to the connector, reassemble. I’ll link some videos related to it.
Hope it works out for you, if you can’t do any of this most you can do is buy a can of compressed air and dust it. Here’s the links:
Disassembly: https://youtu.be/bF1V1QiB17c
Fan replacement: https://www.amazon.com/dp/B01ARKWV5E/ref...
If you wish to change it, some good thermal paste: https://www.amazon.com/dp/B0795DP124/ref...
Puntuación 0
Añadir tu respuesta
Lorenzo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 24
Ultimos 30 días: 138
Todo El Tiempo: 156,041
