Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1233 Ver todo
Doesn't recognize SIM card
iPhone 5c will not recognize sim cards. Can i replace sim card reader in iPhone 5c?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Unfortunately, the SIM card reader is attached to the logic board and cannot be replaced independently. You might still be able to troubleshoot this though. First give the phone a reboot if you haven't already. If you you're only having a problem with one SIM card, try cleaning it's contacts with a pencil eraser, as they may just be dirty or corroded. If you're having a problem with multiple SIM cards, try the pencil eraser first, then try a network reset (Located in Settings>General>Reset>Reset Network Settings [in iOS 7]). If this doesn't work, try restoring the phone with iTunes. If you're still having a problem, try taking it to the carrier store and seeing if warranty will cover repairs. Good luck!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
bmcpa11 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,072
