broken charger connecting(micro usb) port.
my galaxy note 10.1 is not working because it was broken micro usb port for charging. so where can I repair it in anchorage? or how can I repair it in anchorage?
Es esta una buena pregunta?
Hi,
The charging port isn't soldered to the main board. Replacing is easy, because the charging port is on the flex cable. Look here step 15, pic. 2
Samsung Galaxy Note 10.1 Teardown
But you must have some experience to disassemble the Touch screen & LCD display module. It's held by screws and clips.
Regards.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 5,271
1 comentario
Good information here on teardown but does anyone have a suggestion on where to order the replacement port/dock connector? I've looked and I'm getting flooded with 2014 model info. Mine is the 2012 version. Thanks for anything you can share to help.
- de Tony Perez
