Saltar al contenido principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
Preguntas 526 Ver todo
Samsung Galaxy S4 Active won't charge after new port?
I changed the charging port but the phone still will not charge. Anyone have any idea??? I also changed the screen due to the fact that the screen was cracked. It won't even turn on or anything. Help :)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I would make sure that you have tried using different cables to charge it because cables go bad over time. If you have tried new cables then I would try assuming that the part is bad and return it and try another one. If the new part does not work then it is probably an issue on the motherboard.
Hope this helps!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Alyssa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 996
