The sixth generation Grand Prix, a front-engine, front-wheel drive vehicle manufactured by Pontiac, a division of GM. Sold in both coupe and sedan configurations.
Preguntas 26 Ver todo
Won't accelerate when given gas.
This is an automatic 2002 Pontiac Grand Prix SE.
Just revs like you're in park and giving it gas. Uphill is a battle to get it over 10mph. Pressing down on gas pedal, it revs, won't accelerate. Checked to be sure the floor mat isn't shoved up under the gas pedal. What can be causing this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
kkhalid, " it revs, won't accelerate." sounds like a transmission problem. One of the most common causes of transmission slip is low automatic transmission fluid. Check the fluid. Other causes are the transmission band is worn out or broken.
Fue útil esta respuesta?
Calificación 3
I had an issue with my GTP where the transmission control cables were worn, causing extremely slow acceleration until it got to 2nd gear.
Calificación 1
Añadir tu respuesta
kkhalid estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 10
Últimos 30 Días: 42
Todo El Tiempo: 1,082
