The HTC One SV is a sleek 4G LTE capable Android smartphone that combines great sounding Beats Audio™
Preguntas 16 Ver todo
Why does an error message keep popping up?
An error message saying my dialer has stopped working keeps popping up. It gives you an option of send a report or don't send and it pops right back up after you pick one of the options.
I had my carrier factory reset it and it did not help. Please help save my phone.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
4 Respuestas
The issue you are seeing is call "force closing".
If your phone is stock, that is not rooted, then chances are a third party app is causing the problem. If it happens after a factory restore, with no third party apps installed, then you just need to clear the cache.
http://forums.androidcentral.com/verizon...
That's a guide on clearing your cache. You will have to redownload your apps but that should fix it.
Fue útil esta respuesta?
Calificación 0
Comentarios:
i cant clear my cache in htc one m8 due to marshmallow update
por
? Marshmallow has nothing to do with the stock recovery. You absolutely can still clear your cache after the update.
por
Go to settings then go to apps after that go to running apps and uninstall up date on input sense
Calificación 0
I am experiencing the same issues with many apps. Email, clock, dialer etc. I am unable to get into settings.
Same error.
What other options are there?
Calificación 0
SOFTWARE updating problem
Calificación 0
Añadir tu respuesta
Nicole Hallett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 32
Últimos 30 Días: 132
Todo El Tiempo: 9,208
