Saltar al contenido principal
Mediados de 2006 / número de modelo A1181 / carcasa negra o blanca / procesador Intel Core Duo de 1,83 o 2,0 GHz.
Preguntas 418 Ver todo
Can I replace the old Airport Card with Atheros AR5BXB112?
I'd like to use AirDrop feature on my old MacBook, but the original Airport Card inside my MacBook doesn't support it. So I am thinking of replacing it with Atheros AR5BXB112, which is used in MacBook Pro 2009 or iMac Mid 2011. Possible?
Add : My MacBook is a Late 2006 model (A1181) with Core 2 Duo 1.83. (not Core Duo)
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Won't work those are 802.11 ac cards and your hardware (and likely your OS) wont support them. If you really have to have this feature see if there is a USB wireless dongle that will support AirDrop in the OS you're using. (FWIW I would not recommend trying to run Mavericks or Yosemite on a machine that age).
If this answer is acceptable please remember to return and mark it.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
RadioMan28 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 476
