Repair guides and support for Kenmore washing machines.
Preguntas 1211 Ver todo
Kenmore 110 Washer won't drain or spin? solved
I was doing laundry and machine was working perfectly until it got to a point where water gets drained.. no any kind of sound or noise that it's even trying to do anything, water just sits there in a washer.. Any suggestions what is happening with it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Is the load balanced? Is the drain hose clear and unclogged and unkinked?
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Yes it was a lid switch issue.. it's fixed now! Thank you!
por
Añadir tu respuesta
Edzile estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 9
Últimos 30 Días: 16
Todo El Tiempo: 619
