The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
Es esta una buena pregunta?
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
Guía
Dificultad:
Difícil
15 - 25 minutes
Guía
Dificultad:
Moderado
30 - 45 minutes
Fue útil esta respuesta?
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
Mine is the same as Amos. Sleep mode . Wont wake up.
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 9,138
4 comentarios
It will work with A mouse
- de hmrogers01
the glass is cracked will this keep it from working
- de hmrogers01
It isnt working not alittle.
- de Richard James
my screen is cracked and the same thing happening how do I fix this
- de Fantasy Anime Lover
