Why don't the buttons on my calculator work?
When I press the buttons on my TI-36X, nothing appears on the display.
Es esta una buena pregunta?
Check if any buttons are stuck beneath the casing. This may prevent your calculator from responding when you press a button. If no buttons are stuck, reset the calculator by pressing the reset button on the back of the calculator with a pen. If none of these steps work, go to our TI-36X Pro Troubleshooting Guide
Fue útil esta respuesta?
not helpful... none of these work
where is the reset button
Yes, thank you so much! Resetting my calculator corrected the problem.
where is the reset button?
Everything about my calculator works perfectly except there are no numbers on the keypad. I have to try to remember where the numbers are at when I am typing because there is nothing there. What is wrong with my calculator?
My calculator can’t on..can you tell me the factor why it can’t on?
so my calculator won’t work and it just shows on the very top corner error and the number I type in barley shows
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 14,155
Kevin Rangel, does your calculator turn on at all?
- de oldturkey03
I hqve this problem also.
it remain on and no button are working .after sometimes it is off.i tried several times but the problem remains same.please guide me to solve thus issue
- de krishna mohan mishra
