Saltar al contenido principal
Guías de reparación del Motorola Moto G. Una serie de Smartphones Android fabricados por Motorola Mobility desde 2013.
Preguntas 970 Ver todo
Having an issue with my Moto G starting up.
My phone will not turn on fully after shutting down by itself from a low battery. I came home from work, plugged it in to charge it (which apparently hasn't worked) and what happens is it will turn on, show the start up screen with the Motorola logo on it but it won't even make it to the home screen before it goes black and restarts the process all over again. It doesn't respond to being plugged into a charger and I've tried a normal power up through Fastboot. I'm unsure what to do at this point, wondering if this keeps happening if it is going to cause any permanent damage to the phone or if I should wait until the battery dies completely. Any help would be appreciated. I'm hoping I don't have to replace the phone considering I've had it less than a month.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
2 comentarios:
I accidentally drpped my moto g in water and exactly same thing is wrong with it :(
- de
did you change battery? was it helpful?
- de
Agregar un comentario
2 Respuestas
Dia, sounds like your battery is no longer holding a charge. I would start with a new battery first. If that should not work, you may have to take a closer look at your charging port, make sure it is clean, not corroded and does not have any bend or broken pins. But, start with a new battery first. Of course if you " I've had it less than a month." check to see if you have some kind of warranty etc. If you do, use it. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
The phone isn't even a month old and I bought it brand new?? Earlier in the day it was charging fine/working fine. It just hasn't turned on properly since it shut down automatically while I was at work because the battery was low.
- de
In that case do not do anything but have it replaced under warranty. Having issues like this that early, I would take no chance and get a different phone.
- de
my motlrola moto g runing completli but this make time not start..charging the phone than press the power key but not starting only flash on notification light countinue..please he what i am doing ?
Puntuación 0
Añadir tu respuesta
sdfdsf estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 4,185
