Saltar al contenido principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Preguntas 201 Ver todo
forgotten my unlock standby screen pattern
how do i get the standby screen to unlock , as i have forgotten my lock pattern
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If you've created a google account, after several tries you can see at the bottom it will ask "forggot pattern?" You can then enter your email and password and it will ask to set up a new pattern
If you haven't, I hope you've backed everything up because you have to do a hard reset of the phone, it will wipe your phone of all data but you will solve your problem.
To do this,
1. Turn the power off. Remove and replace battery.
2. Press and Hold the Volume Up, Home and Power button.
3. When the start up screen show, release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset"
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
  • Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
  • Allow several minutes for the reboot process to complete.
If the information is important to you, you can recover data from an app located here:
http://www.recoverandroid.net/samsung-ga...
You will have to purchase the app, however.
Here is a video of how to use the program
http://www.youtube.com/watch?v=3HWLGBMmx...
If you have any further concern please come back and we will continue to assist with your troubleshooting needs.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I did the above 3 times and it didn't work. I have a phone (Samusung Galaxy S) I didn't use for 11 months because I got an upgraded to a new phone (Samsung Galaxy 4) . My new phone broke. I dug out my old phone, I had forgotten the pattern and in that time & had I deleted my gmail account. I got locked out. I did the above and it didn't work.
- de
Añadir tu respuesta
joos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 4,360
