How does the reset work on the Fitbit Flex?
Can the Fitbit be reset without the OEM charger? I lost the charger and got an after market one, but it doesn't have a reset pin. Is it just a case of shorting the pins? Or is it a matter of applying 5V+ to one of the other pins?
Es esta una buena pregunta?
4 comentarios
I have same problem. I live abroad and there's no way to get original charger here. My fitbit is not syncing and I need to reset it badly!
- de alkithilien
Plug the bracelet in the wall charger and do the following to rest the Fitbit flex hold the button down on the side for 10 sec the software version should appear and you should be able to charge it again if the battery was completely drained. You should see the green LEDs also flash indicating it was successfully reset. Hopes this helps someone out.
- de Pattie Weiss
Just reset mine per your instructions! I have old car chargers that stopped working. I used one of those. 1) disassembled it 2) took red and black wires off of the board 3) stripped them a little bit 4) plugged in the old charger 5) had my son hold the Fitbit as shown in the picture above 6) put the red wire in the middle and the black wire to the left. It worked and now my Fitbit is charging in the replacement charger I purchased. Thank Chris!
- de Tisherwisher
How can I restart with an Alta without original charger?
- de Deserae Fisher
