Saltar al contenido principal
Guías de reparación y desmontaje de varios teléfonos móvil Samsung con Android, tanto nuevos como antiguos, incluyendo el modelo Samsung Galaxy. Todo lo que necesitas para reparar tu móvil Samsung.
Preguntas 13120 Ver todo
Power button doesn't work on Samsung Galaxy Trend?
I tried the holding of the volume button ad putting the usb in, but it does not work on my device. is there any other way to turn it on?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hello.
Try next steps (apologize for my english, i'm spanish :) )
Hold Volume down and home at same time. Then, plug in the usb cable, previously connected to computer.
The device must go to download mode. Then, unpush both buttons, and press volume down to cancel and restar the device.
Worked for me in Galaxy trend, Galaxy S2 and BQ.
Good luck.
Please, tell me if worked.
Fue útil esta respuesta?
Puntuación 8
4 comentarios:
Thanks alot. I'm in the office, I would have been stranded!! Bless you. PS: You're English is good, don't worry :-)
- de
It worked. :) Thank you so much. I had to plug in the USB cable with my mouth because I was using my other two hands to hold the volume down button and the home button.
I have a black Samsung Galaxy Trend Plus gt-s7580
- de
OMG IT WORKED! I kept finding for tutorials on youtube but they still dont work. Thank you, you are my savior! :D
- de
Brilliant !!!! Are you somehow related to Ethan (Mission Impossible)
- de
What does it do when you plug it in to charge? A lot of times, plugging it in, turns the device on.
Puntuación 0
The volume down n home button trick works very fine. Thank you very much
Puntuación 0
1 comentario:
You are supposed to have someone help you.
Hold the VOLUME DOWN key and the HOME key then plug the USB. Will power up instantly.
- de
Añadir tu respuesta
jasnajasna934 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 4,039
