Saltar al contenido principal
Modelo A1136 / disco duro de 30, 60 u 80 GB / frente de plástico negro o blanco
Preguntas 799 Ver todo
Schematic diagram or Component list
I have a 5th generation ipod that has the no-sound issue, I have isolated it to the capacitor C860 on the logic board as when I press lighltly on it with a plastic probe, the sound works. I have tried resoldering the connections on the board in case of a dry joint, but this did not fix it. My next step would be to replace the capacitor, but I cannot find out what the value is of this surface mount.
Does anyone have circuit diagram or a component list for this device?
You can see it in the photo, it is one of the two capacitors, I assume they are the same value.
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
David, I just measure both of those caps and it comes up to 14uF for both. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
David estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 49
Todo El Tiempo: 3,971
