Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
Preguntas 3244 Ver todo
iTunes Error 3 iPhone can't restore
Hello, I have a problem with my iphone 5 CDMA. I tore my Audio control & Power button flex cable, and I just put it back together, and now I have no service...so I entered my phone into DFU mode and now it can't recover. It gets to a little bit half way and then on iTunes I get Error (3)??? Do I have to get a new cable or what? Please help I've replaced the power button already.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 14
Comentarios:
Hi, I had the same problem and what I did after trying everything else was:
1. Open your iPhone.
2. Remove your screen.
3. Disconnect the battery for about 20 sec.
4. Now try to restore your iPhone without the screen.
5. After your restore is complete plug the screen back in again.
Hope this help
por
Agregar un comentario
7 Respuestas
Solución Elegida
Hi there as far as I no there isn't a fix for this and it's hardware issue.
If it's still in warrenty go and get a replacement.
You can check out information here https://discussions.apple.com/thread/537...
There's plenty of cases to read about on here and some success story's on how to get around it involving puting phone in the freezer I'm not 1 for doing that but if phones out of warrenty and it's basically a brick then there's no harm in trying.
Hope u get it sorted
Fue útil esta respuesta?
Calificación 4
Comentarios:
U could try a new cable an see
If you have tryed everything and still nothing try that freezer trick
por
I FROZE MY PHONE AND IT WORKED! Thank you!
por
gonna give this a go
por
didnt work for my iphone 7
por
Freezer Trick worked!!! I put in there for about 20 minutes in a zip lock bag and it ran straight through!!!
Calificación 3
Thanks, Con
But do you think just getting out of it would me fine?...Like Hold the Power&Home buttons, and get a new cable as well?....if not I'd just have to buy a new phone:( thanks again for taking the time and replying my answer.
Calificación 0
My phone is 20 days old and stuck in this mode. I've done everything that chat and telecom support could offer....reinstalled itunes, switched laptops, pressed home and lock button several times...now the phone is just stuck in recovery mode. I purchased it from Dubai while I was on a vacation. Apparently Apple's policy include no international warranty.....
Calificación 0
Put it in the freezer for 40 minutes. Take it out, plug it into your computer and restore through iTunes. I did it with an iPhone 5 that I was having error 3 with and it worked. The iPhone was not reading the SIM, unless I reset the date and time to an earlier date under settings. I found this answer from Kenneth Young in this thread
Calificación 0
I had the same problem, i solved it by authorizing the pc, mine wasnt. After that the restoring prosses worked fine and i could finally use my iphone again.
Hope it works for you
Calificación 0
kksilvery
I have the same issue with my iPhone , It is a hardware problem.
FIX,
1. Cable.
2. Newly re-placed hardware .
3. Battery change.
4. Logic board or Motherboard problem.
My iPhone 4S 16GB Solution : Replace Logic board or sell it online .
Regards,
kksilvery.
Calificación 0
Añadir tu respuesta
Mikala estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 42
Últimos 7 Días: 249
Últimos 30 Días: 1,179
Todo El Tiempo: 59,554
