Saltar al contenido principal
Modelo A1286. Lanzado en febrero de 2011 / 2.0, 2.2 o 2.3 GHz Procesador Intel Core i7 de cuatro núcleos
Preguntas 586 Ver todo
Backlight is unreliable, behaves intermittently
Hello! I have a laptop, serial F8V, that has an intermittent backlight -- sometimes it's not on when the laptop powers on, and sometimes it is. Sometimes the backlight doesn't come back when the laptop awakens from sleep. You can always generally get it back on, but it takes powering on/off, etc.
The board previously had some corrosion that was cleaned off, and previously was not powering on fully, and just showing a glowing sleep light. So that issue seems to be resolved, but now I've got this backlight problem.
The question is this: Would this problem more typically be the board itself, the topcase/keyboard assembly, or the screen assembly? I don't typically get a lot of the 15" unibodies, so I don't have a really strong sense of what the culprit would be. I vote that the board is bad, since it had slight corrosion (and unibody boards are generally so fragile anyway), but I thought I'd reach out and see if anyone has something interesting to add.
Thanks!
John
Es esta una buena pregunta?
Puntuación 2
1 comentario
Actually that's not the right machine -- it's a 2011 2GHZ i7 quadcore...for some reason EveryMac.com doesn't seem to have its database updated, so it brings up the 2.9GHZ retina i7 instead . When I first plugged it into EveryMac I got really excited, but I quickly realized that it's clearly not the retina model (for one, it has RAM slots).
- de
Agregar un comentario
2 Respuestas
Solución Elegida
The most common problem I've had with these machines is the hard drive/ IR sleep sensor cables going bad. They create all sorts of maladies including sleep and back light issues. They will also destroy hard drives. So try replacing the cable and use a hard drive from a known good machine (any 10.7 + system works for me. If nothing else it's a cheap repair attempt and the first thing I do on these machines. (so keep extra 13" & 15" cables on hand).
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Thanks Mayer! I'm glad I asked, because I never would have guessed that one! So if I don't have another cable, I assume I can eliminate that as an issue by simply disconnecting the cable, and if the issues stop, then that was probably it? Thanks again!
- de
Don't assume anything on these. Remember you loose the sensor when the cable is disconnected. On the newer machines the cable is double the width of this one and there is a rubber bumper on the top of the cable as it goes over the upper edge. I've used the newer cables on the older machines and they work fine. See this question: Using new hard drive cable in older machines 821-1480-A
- de
Have you tried resetting PRAM ? (Booting with Cmd+option+P+R keys)
Next step you can do is trying to reset SMC. (This progress is hard to explain so I refer you to apple's website for that Resetting SMC)
Next up is finding the connectors on the logic board which lead to the backlight. If you see any corrosion/soldering damages, then u might have located the problem. I do not own a tech manual for mbp atm but I'm sure someone on this website can provide you with the location of the connectors on the board.
Puntuación 1
1 comentario:
Yes I've done all the resets and removed all visible corrosion. Thanks
- de
Añadir tu respuesta
rdklinc estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,050
