Saltar al contenido principal
Rear Camera problem - purple dots on pictures
Hi,
my iPhone started to have problem with its camera. On very picture, there are purple dots and it is pretty annoying. Do you think replacing camera should help? I am adding a picture of white paper where are dot shown so you see how it looks. So could you suggest what should i do to repair it?
Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
2 comentarios
Thank you very much!! I changed the camera and it works fine now. It took me about 2 and half hours but it wasn't that hard. Wow. Thank you for your help..
- de
How did u do it?
- de
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Looks like there may some dust particles that have made it inside your camera module. I had the same issue and fixed it by changing the iPhone 5 rear camera.
Good luck!
Fue útil esta respuesta?
Puntuación 2
If the warranty had expired, replace the camera yourself
Puntuación 0
You can open it up, take some alcohol on a quip and clean out the camera, I agree with the dust comment.
Puntuación 0
2 comentarios:
Do not attempt to clean the camera. This is a sensor problem, cleaning won't improve anything, but potentially making it worse
- de
I agree that it's most likely a sensor issue as well, but it COULD be some debris (dust, etc) behind the lens cover as well. I'd recommend against using alcohol or touching the camera directly. I would instead used compressed air to clear the debris.
- de
Do you have a good suggestion for me i have a iphone 8 and i bought it for 2 months ago and i am so sad
Puntuación 0
Añadir tu respuesta
Martin Frank estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 31
Todo El Tiempo: 17,138
