Saltar al contenido principal
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
Preguntas 42 Ver todo
"No Sim detected" problem
The Sim card detection suddenly stopped. Whatever service is put in, no SIM card detected.
What might be the reason?
What is the Fix?
Thanks,
Ravi
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 10
Agregar un comentario
6 Respuestas
Respuesta Más Útil
I found that my issue was that there is a piece of metal at the bottom of the SIM card slot that when you put it the sim it connects with a sensor that tells the phone a sim is inserted. But the issue is the metal cage does not cover the full sim area and the metal arm can dislodge at the bottom and doesn't connect. I had to take the back off and push the arm back in alignment to have it recognize the sim again.
Hope this helps,
Fue útil esta respuesta?
Puntuación 5
A simple solution/work around to this issue involves placing a small piece of tape or paper behind your phone's SIM card and sliding it into place as normal, don't force it, it should slide in smoothly with no extra force needed. If done correctly, this may make your SIM card fit more snug into the SIM card tray and enhance the SIM card's connection.
Puntuación 2
I have this Problem after "NO" remedy finaly went to shop who change the Jacket which cost me a good amount
Puntuación 1
Hi,
I had the same problem and I've found a solution of that problem in youtube. Have a look it might help you as well.
https://www.youtube.com/watch?v=gfNUu4Dj...
Thanks
Puntuación 0
Geniiioooouuussssss!!!!! Thanks a lot!
Puntuación 0
1 comentario:
Which answer helped you?
- de
SIM card in my phone but
No SIM card shows me
Please halp mee
Puntuación 0
Añadir tu respuesta
Ravi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 24,123
