Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2193 Ver todo
iPhone 4S - Error 9 when restoring firmware
Hello
I have a problem with an iPhone 4S. It had some problems from the beginning when i bought it from ebay.
When I was flashing the firmware i had error 4013. I read on the internet that i should replace the USB Cable or the bottom flex cable (with charging port, microphone). After replacing the bottom flex cable I still had error 4013.
I cleaned the motherboard in an ultrasonic bathtub using Isoproppyl Alcohol. Things changed a little bit, now i have Error 9. It keeps putting the phone into the restore mode. Before cleaining it i looked at the motherboard under the microscope and it had no signs of water damage etc.
I have some repair skills with bga and soldering, so if there is a need to repair the motherboard, i would be greatful for any hints.
Here is the video on how it behaves when I am restoring the firmware.
http://www.youtube.com/watch?v=aaPT5Al9o...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Another thing, still sometimes i get error 4014, but most often i have error 9
- de
same problem dude.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
give heat to wifi ic
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Wow, it worked for my iPhone 4s, thanks a lot bro!!!!!!
- de
What did you use for heating the wifi ic?
- de
Hello, it did worked for me just a few hours, after the wifi ic was getting cold, it did not work again. So my solution is, to replace the wifi ic. To heat the wifi ic i used a heardryer.
- de
try changing battery
and restore with a working battery
it worked for me.
Puntuación 2
2 comentarios:
Wow, thank you bro, it worked for my iPhone 4s.
- de
Great , thats nice
- de
Añadir tu respuesta
JackVonThor estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 9,681
