Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1203 Ver todo
The new hard drive won't slide in
I am installing a new 500 GB 7200 RPM Seagate SATA Hard Drive. I am at the point of sliding the new HD in the silver bracket back into the Mac, but it doesn't seem to want to go the last 1/2 cm or so. I don't want to force it as I am pushing pretty hard. When comparing the new HD to the old one, there is a difference in the area around the 4 copper pins (jumper block). The new one has a plastic collar or border (see http://www.seagate.com/images/support/en...), while the old one doesn't. Could this be making a difference?
Es esta una buena pregunta?
Puntuación 2
1 comentario
well stated question +
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I have had this problem, and for me it was the rubber shock grommet bunching up around the corners in back and preventing the HD from sliding in the whole way. I took the top case off and put the grommet around the HD and placed it in. Then it worked.
Fue útil esta respuesta?
Puntuación 6
6 comentarios:
I'll give your solution a try. That maybe the problem. My wife had originally installed the new HD upside down. Perhaps that bunched up the rubber shock grommet. I just tried re-installing the original HD and it won't slide in either. Thanks.
- de
That was absolutely the problem! The rubber shock grommet was bunched up and not allowing the HD to slide in! Kind of a cheap way to have the grommet attached on both sides though.
Thanks so much for your great answer!
- de
excellent +
- de
I had the exact same problem! thankfully i found this and realised what had happened. and it was easy to fix once i knew what to do!
thanks alot guys!
- de
Thank goodness I found this - I couldn't work out why the hard drives wouldn't slide back in (new one or old one!!).
Took top case off using iFixit's guide, repositioned grommet and it was all fine :-)
Thanks everyone!
- de
Mostrar 1 comentario más
Añadir tu respuesta
rsweeney79 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 4,895
