Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
iPhone 4 Doesn't Charge
Hi,
I own a Iphone 4.
It doesn't charge and it isn't recognized by ITunes.
I've changed the charging dock but still the same problem ...
I tested the phone with a charged battery and it works ...
Could you help me ?
Best regards
Es esta una buena pregunta?
Puntuación 3
5 comentarios
After inquiry, there were splashes of water on the phone ...
- de
I did another test : I used a charged battery --> the iphone goes on
--> ITUNES recognize the Iphone --> the symbol "charging" appears when the iphone is connected ---> BUT it doesn't charge
- de
sounds like a bad charging coil or power IC. The coil would be my first choice
- de
Is it easy to change ?
- de
no, not an easy repair. It does require good soldering skills and the right tools. If you are unsure about soldering it yourself, I'd suggest to find somebody close to you that can do SMD component soldering.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
fred, the "not charging" can be caused by multiple things, like the cable, dock connector bad battery, bad charging coil as well as other components. Check for corrosion, loose connection etc. on the logic board. I marked the most common issues on the diagram. Check for continuity etc.
Start by cleaning the dock connector properly, replace the battery, make sure the battery connectors are properly attached to the board. Worst case scenario, you have issues with the power management IC. check this video for a reflow and the image to see if the jumpers might help you out. Place jumpers across the fuses
. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
The USB power fuses are OK ... How can I test the USB power IC. Is it easy to replace ? If it's the power management IC .... i can't do anything ... Many thanks ...
- de
It's almost certainly the logic board.
Puntuación 0
Añadir tu respuesta
fred estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 4,014
