Saltar al contenido principal
El RIDGID R84015 X2 es un taladro inalámbrico con mandril de 1/2 pulgada y 18 V.
Preguntas 6 Ver todo
Battery no longer holds a charge
The 18v batteries for my RIGID tools (drill and reciprocating saw) no longer hold a charge.
The charger even signals that one (I have 2 packs) of the batteries is defective (blinking red & green lights).
Do I have to replace the packs (over $100 each) or can I possibly replace the cells inside the packs?
Thanks in advance,
Paul
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
paulk524, you can replace the cells. Take a look on here . Biggest issue will be to open the battery pack. Once you have it opened, the repair will be similar to this Repairing a Cordless Drill Battery or this one Repairing Black and Decker - TS221 Ranger CD2000 Battery Should cost you no more than around $40 to rebuild the battery. Hope this helps, good luck.
Imagen de Power Drill
Guía
Dificultad:
Moderado
Imagen de Black and Decker TS221 Ranger CD 2000
Guía
Dificultad:
Moderado
1 - 2 hours
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
paulk524 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 16,729
