iPhone 5s battery on iPhone 5
Is it possible to upgrade the iPhone 5 battery with the iPhone 5s battery?
I mean, same connector or same size ?
Update (11/30/2013)
I had the same thought (I am also having battery problems with my iPhone 5).
However, after a quick look around the iFixit site it's clear that the iPhone 5S battery is not available for purchase anyway (as of Nov 30, 2013)!
I'm just getting the iPhone5 battery. Even if we assume everything is perfectly compatible (which is a HUGE assumption that will probably blow up in our faces), the percentage change between the 5 and 5S batteries is only 8.33% ((1560-1440)/1440 = 0.08333). Normally, I expect to get ~16 hours of 'general usage' (my iPhone usually dies right before I plug it in at night). In theory, 8.33% would only bring you up to 17 hr 20 min; not exactly a difference what would justify the risky assumptions involved.
Es esta una buena pregunta?
3 comentarios
The reason I ask is because according to an Apple Genius who ran a diagnostics test on my iPhone 5 (which I purchased the day it came out) my battery decline is attributed to the battery being bad and not iOS 7. I was going to buy an iPhone 5S battery rather than an iPhone 5 battery and install it in my iPhone 5. I need a new battery regardless so I wanted to know what was the smarter choice.
- de afabuali
Redradioflyer, great math if the usage depletes the battery consistent, which I doubt. I go more with an exponential depletion and would like to bet that the battery will only make a difference of minutes. BTW the connectors between the iPhone 5 and iPhone 5S are totally different, it will not fit....excellent answer.
- de oldturkey03
Thanks OldTurkey! I suspect you're right about the exponential depletion (especially for the last ~10%). Since I was arguing against the battery change I picked assumptions to make the best possible case for change (I probably should have stated that). Fortunately, your answer gets right to the heart of the issue... If the connector don't fit; it's time to quit!
- de Redradioflyer
