Saltar al contenido principal
Phone is not turning on. Keeps showing Samsung?
Today I downloaded a .zip (1% Battery Mod) file from this page:
http://www.galaxyyarchive.info/2013/07/1...
I went to recovery mode and clicked 'apply update from .zip file' and opened that downloaded file. Then i rebooted my phone again. Since then, whenever i turn on my phone it keeps flashing Samsung continuously and doesn't start.
What should I do?
Es esta una buena pregunta?
Puntuación 113
28 comentarios
For me it just shows "samsung galaxy y 5360 " and not able to boot and not able to go to recovery mode also ....pls help
- de
what the answer for this question?
- de
Hi I'm Vishwa
I kept my S3560 mob for charging longer time by then it is not powering on, I tried hard reset however im unable to power on my mob.. is there any troubleshooting step that i can perform and resolve this issue...
- de
as you described ,the must could be hard bricked.
- de
Has anybody figured out how too fix it yet or ?
- de
Mostrar 23 comentarios más
Agregar un comentario
11 Respuestas
Solución Elegida
Follow this:
http://www.galaxyyarchive.info/2012/08/f...
Fue útil esta respuesta?
Puntuación 10
6 comentarios:
please help me I have samsung galaxy s duos and it is not starting when I push the power button it even do not starts or vibrates I cannot able to go to recovery or download mode plz help me plz
- de
its the same problem on charging? well if it doesn't charge your samsung, you should contact samsung service for further tests. the problem maybe its on motherboard inside (the charging socket) maybe the wire disconnected or got dusts or rusts
- de
I have the same issue: I can not start my samsung galaxi duos and the battery is charged 100%.
What I can do?
- de
It just showing samsung on the screen
- de
My Samsung Galaxy J 2 is turning on and off but doesn't be on, this happen after the battery is charged 100%. I tried to press volume and power button at the same time but it's still not working is just turning off and turning on. please help
- de
Mostrar 1 comentario más
See this video; https://www.youtube.com/watch?v=Qt2oWoub...
Puntuación 6
6 comentarios:
Thanks Berenice C, Really this is very helpful video.
- de
How Video Berenice Carissa
- de
PLZZZZ Hellp meeee
- de
Thank you. I back in contact with the world
- de
thank you so much ..it was the power button
- de
My Samsung Galaxy Young wasn't turning on and simply showing the samsung logo and the twinkling light behind it. I did a restart by holding down the power button, the main button and the volume down button. It worked like a charm!
Puntuación 4
4 comentarios:
when my note 2 suddenly switched off , while opening, it only showed the logo and hanged on....even though i tried these methods from youtube but again it stops at the logo....what to do
- de
Yes mine too...the same thing happened...it switched on and the logo showed up and dint go ahead. I pressed the three buttons too (power + volume up + volume down) but still it's not starting up or rebooting. Can you suggest something else please?
- de
What I can do?
- de
Yes it also worked for me. The downloading screen was kind of stuck so I had restarted my phone, it restarted but phone moved only 2-3 screens further and again it went to Samsung logo. I again went to same process and left the Downloading process for more than 3 hrs and restarted my phone. And now it is working as brand new phone as if we bought it.
- de
Try a Factory Reset by the updat mode combinate buttons power+home+volume down
Puntuación 3
1 comentario:
also can not turn on i need maybe software i do not know
- de
Hi There,
I also had same Problem and I followed below step:
1. Press power button to shut down you device
2.Press Power button+vol Up+ home key simulteneously
3.select"wipe data / factory reset" using Volume buttons to navigate and Power button to confirm.
4.Choose "Yes -- delete all user data" to confirm the whole operation.
5.After that select option "reboot system now".
6. wait for around 15 sec and there you are!! follow the steps to configure it.
Puntuación 1
1 comentario:
its saying android no command head info failed
- de
I think you might wanna give you some tips on this -
try a hard restart on your phone
Plug it to charge and leave for 20-30 min and than try restarting your phone
and than first You may want to boot your phone in safe mode see if that help
thanks and i hope this will help
Puntuación 1
Hi,
Can you try and go back to recovery mode.
after that erase data or whatever its says first.
Then you can reboot the device see if it works.
If it did your welcome.
if it didn't then go to a service provider.
Puntuación 0
1 comentario:
It just showing welcome and start but I'm not able to click start.
- de
i had this problem. I've scrolled all pages looking for answers trying all of the different ways and it just wasn't working. So i learned that if all else fails , just get a new battery.
Puntuación 0
1.Turn off your phone
2.Press together volume up + home button + power button
3.Release your fingers of the phone when Samsung logo appear
4.Choose with volume buttons "wipe data/factory reset" and select it with power button
5.Choose "yes" with volume buttons and select it with power button
6.Wait untiil format is complete
7.Select "reboot"
8.Wait until the phone restarts
That's it!
Puntuación 0
try to download new firmware you can download it to google and and use samsung kies software to reprogram your device.
Puntuación 0
1 comentario:
Hi guys
I have a samsung j1 and i'm unable to remove the exclamation mark on it and its urgent
Try to give me a solution guys
- de
7.Select "reboot"
You are good to go!
Puntuación 0
Añadir tu respuesta
rohanbaranwal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 32
Todo El Tiempo: 172,601
