Location of cylinder 6 on the Lexus ES300 engine?
Es esta una buena pregunta?
Hi. I found this answer on wiki.answers.com, so I'm not entirely sure if it's correct. I'm sure the community will correct me if I happen to be wrong. "The number 6 cylinder is located on the drivers side front toward headlights, here is the entire order: pass side back by firewall = 1, center=3,drivers side back=5 and the front cylinders are: pass side front=2, center=4, drivers side front=6"
Fue útil esta respuesta?
I replaced the coil on the #6 cylinder which was having an error, and can confirm that the #6 position is correct
Ultimas 24 horas: 1
Ultimos 7 días: 22
Ultimos 30 días: 86
Todo El Tiempo: 21,563
