The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
Preguntas 612 Ver todo
What is the part below called? And how do I fix it?
My friend recently dropped my Galaxy S4, I thought it was the mid frame that was damaged but it isn't. It is the part between the mid frame and the screen. Anyone knows what the name of the part is called? How to fix it? Thank you very much ;P
I think it's the "QFR01", where do I buy that part? And how do I replace it? Is it possible to change the SD card inside my phone along with the system? If so, where do I buy the parts and how do I replace the system files?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
2 Respuestas
Solución Elegida
Patrick, let us know which part you are referring to...
That looks like your display assembly. Looking at the explosion drawing, there is no part between the midframe and the display.
Fue útil esta respuesta?
Calificación 3
Comentarios:
por
Replace your SD card? You mean the reader? QFR01 is the display assembly. Here is the guide for it Samsung Galaxy S4 Display Assembly Replacement
and the display is available either here or on here. It depends on your carrier.
por
Mine is actually the international version w/o carrier, and the system/SD card I mean the part in my phone which stores all my system files and data (NOT ext. SD) ;)
por
That must be your SD card reader. Lets see what the manual says :-)
por
I mean I wanted to take out the 16gb chip and replace it with a 64gb one.
por
Mostrar 3 comentarios más
It's called the bezel. You can order it on its own or as piece of the display assembly (LCD included). I'd suggest www.aliexpress.com
Calificación 1
Añadir tu respuesta
Patrick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,585
