A tablet developed by HP in 2011 running the webOS platform. Boasts a 9.7" display, and is available in 16 or 32 GB. Repair is straightforward, but requires time and persistence.
Preguntas 61 Ver todo
Is my Digitizer or LCD screen broken?
Can someone tell me if my digitizer or lcd is broken? I am still able to click apps on the screen.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
My phone screen is also broken.but picture of phone display is ok. But touch works only to that area where screen is not cracked.what are the chances
por
Agregar un comentario
3 Respuestas
Respuesta Más Útil
In this case the LCD is broken. The Digitizer is that part of the pannel that is sensitive to touch. The LCD actually shows the image. If there's something wrong with the image, it's the LCD. So to answer your question, the LCD is damaged
Fue útil esta respuesta?
Calificación 1
Darby says right. If the screen doesn't response when you touch it, it will be the digitizer issues. You said you're able to click apps on the screen, so the digitizer is OK.
Calificación 0
You said you can click Apps, i believe your Touch Screen Digitizer is working well. From your picture, i think your LCD Display is abnormal, you have to replace a new LCD display. Just replace the lcd, not the digitizer.
Calificación 0
Comentarios:
I have a problem with my note 5 pro device.All is ok but there is a crack on screen and there us nothing another problem.what i do...
por
Añadir tu respuesta
AJC estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 4
Últimos 7 Días: 33
Últimos 30 Días: 184
Todo El Tiempo: 15,658
