The Kenmore Elite HE3 is a washing machine by Kenmore.
Preguntas 582 Ver todo
will not start,and door does not lock.
will not start. the door does not lock.
help!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Door or Lid Latch Assembly
If the washer lid or door won't lock the lock and switch assembly might be defective. This is a very common problem. The lock and switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
Main Control Board
If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
peter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 14
Últimos 30 Días: 62
Todo El Tiempo: 1,411
