How do I pull one of these apart?
I have had this speaker for a few years and it has just stopped working!! Does anyone know how to pull one open so I can try and getit working again?
Es esta una buena pregunta?
Rod, here is what I found "Pull away speaker mesh grill. Using a sharp knife or similar carefully lift off the black facia plate. The facia is about 1mm thick and is glued to the speaker plate. Take care not to bend it as you rip it from the glue- bends make it harder to replace in position later. With the fascia removed you reveal eight dark-brown screws that hold the speaker plate to the box and silver screws that hold the speakers in place. After removing the 8 screws the speaker plate can be lifted from the box. Several cables with plugs are very short and will pull the plugs out of their sockets if you lift the speaker plate away. It may be better to first remove the 4 screws from the central speaker- lift it to one side and reach in to carefully note where the cables attach and remove them gently with tweezers or needle-nose pliers.Note-the speakers are very fragile. The cables are- 1) Large 4-pin to central speaker. 2) medium 2-pin to right speaker 3) medium 2-pin to left speaker 4) Minature 3-pin 5) Minature 6-pin to fascia LED and remote sensor. Reconnecting these cables when you put the speaker plate back in place is very difficult through the speaker hole" from here
Hope this helps, good luck.
Fue útil esta respuesta?
Here's a video on it: https://www.youtube.com/watch?v=DpYHUPhd...
I just disassembled it and had little trouble putting the connectors back in. The large ones are easy and the two small ones can be pushed in with tweezers.
HI!
Yes it better to use hot air to help the glue to stick out because it's very fixed and i don't know if i can without that help.
Opened it sucessfull.
My problem was to find a replacement dock and it was difficult to find, and for those who need to replace the part 820-1794-A, can find the connector here:
http://www.aliexpress.com/item/Iphone-30...
Hope i can help someone! Regards
atencion¡¡¡ puede ayudar con una pistola de aire caliente para que el pegamento sea mas suave ok
atencion¡¡¡ can help with a heat gun to glue is softer ok
ok ,gracias si lo logro avisare mi experiencia para ayudar a otros.....thanks.
Google Translation
thanks if I succeed'll call my experience to help others
I've got the thing apart and it looks like one of the big capacitors on the psu has popped. Anyone know if I can get a replacement board or if I have to try resoldering. (Mains fuse blows instantly on plugging it in)
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 24
Todo El Tiempo: 7,148
2 comentarios
does anyone know where i can get a replacement speaker grill for my A1121 unit please send link to jose.barrera476@gmail.com
- de josebarera
I've finally had a good enough reason to take mine apart - also made a little video guide on it: https://youtu.be/XDZHdHXCAZA
- de Darie H
