Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
Preguntas 1956 Ver todo
-1 error in iTunes restore iPhone 3GS
Hi am trying to restore my iphone 3gs in itunes but i keep getting errors . The main error i get and is stuck on finding on the net is error -1. I have tried with different usb cables to see if that was the problem but it wasnt. I have tried with nemourous computers but it keeps saying the same thing error -1.
It gets halfway through the restore/ and it still sais error-1 it is frustrating me!! I need help to try and find this error so i can use it for its purpoise.
is a hardwear error is it a softwear error
if it is a hardwear what is neded for me to fix up the phone.
if it is a soft wear error what is kneeded of mr to fix it
pleas help me
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
2 Respuestas
Solución Elegida
username1107, try this: Unplug the phone from the computer. Leave the other end of cable still plugged in the iPhone, now turn the phone completely off, hold home button still while plug other end of cable into your computer, only release Home button. After itunes recognize your phone in recovery mode and that when you heard the USB sounds on your computer. Press shift+ restore to restore your phone. Take a look at this site as well. The error -1 and 1 are most likely caused by baseband errors. They are very hard to fix. Hope this helps, hood luck.
Fue útil esta respuesta?
Calificación 1
Comentarios:
that error was fix got another error but i know how to fix this one thanks so much for the help
por
Thank you for accepting my answer. Best of luck to you.
por
Handy link:
http://support.apple.com/kb/TS3694
That page lists some error codes, but doesn't suggest anything specific for "-1". Recommends trying to restore on another computer but nothing further if that doesn't work.
Calificación 0
Añadir tu respuesta
username1107 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 10
Últimos 30 Días: 30
Todo El Tiempo: 15,656
