Saltar al contenido principal
¡Los auriculares estéreo Skullcandy Skullcrushers Subwoofer en Black Pinstripe literalmente bombearán la música directamente a tu cabeza! Estos poderosos audífonos cuentan con un amplificador de bajos en línea ajustable y altavoces con los primeros subwoofers vibratorios incorporados en la industria. Puede ajustar la cantidad de efecto de graves con la rueda de control en línea.
Preguntas 11 Ver todo
The left side of subwoofer
Hello i have to repair the left side of subwoofer in skullcrushers, and there is a question:
the subwoofer has 4 slots:
"LV+"
"LV-"
"RV+"
"RV-"
which of them should be paired with following cables:
"red-blue"
"red-gold"
"Green"
"blue-gold"
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Perhaps you could take apart the right side and see which ones match there (from my experience in audio, they should be exactly the same)? Bonus Internet points if you make a guide for it :)
- de
Agregar un comentario
1 Respuesta
Solución Elegida
bartek94to, attached image is what I come up with on the opposite end. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
I did it like you had wrote me. But i can't even hear any bass : | maybe this subwoofer is just broken
- de
Try to bypass and go right for the speakers. See if that makes a difference.
- de
i don't realy know what do you mean : p and i am sure that i couldn't do that, cuz i am novice : | Have you got skype?
- de
Try to bypass the amp. You will need the end that comes from the jack. See the repair 3.5mm jack on the device page Reparación del Enchufe de 3,5 mm de Skullcandy SCS-SCBP SKULLCRUSHERS Connect Gold, Blue Gold RV- and LV- Red/Green to ground, L+Blue and LV+Green to the left, and R+ Red and Red/Gold RV+ to the right. sorry, can't Skype until I get off work. My Skype ID is in my profile.
- de
Añadir tu respuesta
bartek94to estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 1,037
