"Temperature" screen even when the phone isn't hot?
After changing my battery, the battery works fine again, but a few days after I changed it, I started having "overheating" problems. These are not actual overheating problems, because the phone isn't hot, but it keeps showing me the "Temperature" warning and telling me I can't use the phone until it cools down.
This has happened fairly constantly at seemingly random times, and thus far, the phone has never been hot to the touch. It even happens while the phone is physically cold to the touch (outside in 20 degree F weather, for example).
Today I can barely use the phone, it just says "Temperature" pretty much all the time. For a few seconds, sometimes it goes back to the normal swipe-to-enter screen, but it goes right back to the Temperature warning screen after that.
Everything else on the phone works, so I'm sure the repair went smoothly otherwise. Again, this took a few days to start showing up.
Here are the relevant facts, along with some things I've tried to troubleshoot and such:
- I installed a CPU monitor but nothing seems to be taking up the CPU or anything like that.
- I've killed all the background apps and it still happens. I've also left it on airplane mode for hours and it still happens.
- I've tried a full reboot, as well as a restore from backup.
- The battery is not draining faster than normal or anything like that.
- This phone has no history of water damage and i don't sweat a lot or anything like that (nor do I keep it in my pocket).
- I've never seen this temperature warning before swapping the battery.
- I don't use a protective rubber case or anything like that, the phone is just sitting on my desk.
- Charging the battery no longer works because it doesn't seem to charge while it's on the "Temperature" screen.
- I saw no corrosion inside the iPhone at all when replacing the battery.
I'm running the latest firmware (6.0.1) and it's not jailbroken.
Thanks for your help!
Es esta una buena pregunta?
4 comentarios
I have the same problem except itss not with the battery. It fell out of my pocket when i was driving a fourwheeler and the screen shattered and the back is pretty bad. it functioned for several weeks but recently it started giving me the temp. thing all the time. its an ipod tho
- de maddyrose
I have the same problem, I changed the battery once. but after one day the problems back again . could you help me that how i can fix it ?
- de hessam
I have the same problem but mine is an iPhone 4 and the temperature screen will come on then go away and come back on I don't know what to do
- de Madison K
Same $@$* on the XR 7 years later!
- de beinghound
