Saltar al contenido principal
Modelo A1312 / Mediados de 2010 / 3.2 GHz Core i3 o 2.8 y 3.6 GHz Core i5 o 2.93 GHz Core i7, ID iMac11,3
Preguntas 383 Ver todo
Monitor shuts off but computer still running
Sometimes with no apparent correlation with internal hardware temperature my iMac screen shuts off, but the computer itself still running (I can type something, use it...as usual, but the monitor is off. I can see my desktop if I point it to direct sun light).
I've tried to restore the original configuration but it's the same.
There is not an exact delay time before shuts off; it can happends some minutes after startup, some hours later or some weeks later.
To restore it I need to put it in stop (with the power button) then press it again to awake it. It turn on again without any problem.
iMac 27 Mid 2010-Intel i3 3.2-2GB DDR3 Ram, OSX10.8.2,ATI Radeon HD 5670 512 MB.
Any idea?
Es esta una buena pregunta?
Puntuación 7
10 comentarios
I've tried with PRAM reset (5 times) but nothing is changed. After a day the problem is here again. I've turned my iMac in sleep and resumed it.
At Genius bar a technician said to me:
A) it could be a problem the power cable of the monitor (about 100€)
B) ... or with the graphics card (about 200€)
C) ... or with monitor itself (about 300€)
I really don't know what I should do to repair it. This strange problems does not happends every time...it's random... and it's the same since months...
- de
Hi Dan, I'm sorry to tell you the only way to get this fixed is by ringing Apple, even if your mac doesn't have a warranty. It is a real frustrating thing, you think maybe is fixable, but it's not. I have repaired computers for some time and i stopped it happening for a week, but then it went back. Apple replace me logic board first, but it still didn't fix it, Apple then replaced the graphics card and the screen and that has stopped it doing it. So contact Apple, tell them even an windows computer would last longer yeah right. And you didn't pay $3000 to have this happen 5 years down the track, be nice and good luck. All the best
If they don't fix it, is an expensive job to replace the 27" screen.
- de
Mine was doing this. I removed all the dust inside the computer, especially around the RAM slot, where it appears to take in fresh air. There was a lot of dust. Then I installed Mac fan control. Between those two actions, it has not shut down since, about 4 month and running.
- de
I posted here Oct 2016 with my fix, ( dust removal and fan control) which worked until a week ago. That time the monitor shut off once when I was running multiple tasks. So, upon reboot, the screen came back on, and I set my fan control manually, increased the speed to about double, especially for the CPU. Seems to stay on as long as it gets the extra cooling....would be my conclusion.....but still openminded.
- de
@jurgenkoppen - Sounds like you'll need to pull the GPU off so you can clean off the old thermal paste and replace the thermal pads with new ones
- de
Mostrar 5 comentarios más
Agregar un comentario
5 Respuestas
Solución Elegida
Your LCD backlight is on the way out. You could either connect to an external monitor or get/do a LCD replacement.
If this answer was helpful please remember to mark it accepted.''
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
it is not this. i had replace this and charge me and the problem persisted.
- de
It's the back light of the screen which has stopped working sounds to be a common fault with imac computers buy a windows laptop and never have to deal with that $@$* again. My $4000,00
Imac shat itself after 3 years now in a box in the garage ready to be dumped, the biggest waste of money I've evey lost with no help from Apple
- de
Respuesta Más Útil
I just read this: The cause is heat. The SMC fan is not cooling down the system which is then shutting down because of the heat.
There is a temperature sensor in the drive to supposedly prevent this. However, if you've changed your drive like I did, and replaced it with a drive that did not have a temperature sensor, thent he fan controll gets all confused, doesn't turn on properly, everything heats up and then shuts down.
This also happens on factory installed drives when the temperature sensor goes bust. A lot of Apple's early drives for iMacs and MacBooks were really cheap and the sensor failed. I had to replace my factory isntalled drive because it failed. (Thank you time machine).
The solution is a simple FREE software download called SMCfancontroller that turns your fan on at specific RPMs, and turns it off when you aren't overheating. I installed the software and haven't had a "go to black" moment since. The software can be downloaded here: http://www.macupdate.com/app/mac/23049/s...
Puntuación 6
2 comentarios:
The fan is fine, yes it looks like it's getting hot in there at times around 50c, you can download Macs fan controls cooling won't bring back the screen from cutting out. It it was overheating the whole computer would shut down, these computers are still operating in the background.
- de
Done the SMC thing, done the open up and clean the dust thing, done the reset the PRAM and SMC. Done everything. Have been dealing with this for years on and off. All nonsense, It's Firmware problem.
- de
My MacBook never had this problem until I replaced the magsafe adapter with an non-Apple charger (the Ostrich Replacement Macbook Charger 60w Magsafe L-Tip Power Adapter Charger) during the heat of summer. Whenever I was working the CPU heavily while the ambient air temperature was hot (20-25C or so), first the monitor would repeatedly shut off, and soon the entire machine would spontaneously shut down completely. The computer felt quite hot, so at first my solution was to shut it down for 20 or more minutes to let it cool off. But whenever I used the MacBook for long periods of time in hot temperatures, even this proved to be only a temporary solution. Ultimately, I ended resting the machine on top of a medical cold pack just to keep it running for an hour or less at a time. I then tried three of the solutions mentioned in this thread.
First, I tried resetting the PRAM, but this had no effect at all, as far as I could tell.
Second, I followed @jurgenkoppen's suggestion and downloaded smcFanControl, but unfortunately it didn't help nearly enough. I then switched to a different fan controller, MacsFanControl (https://www.crystalidea.com/macs-fan-con...), which worked much better. It's slightly more complicated to use than smcFanControl, but not by much; I set it to display the temperature of the CPU Diode, which consistently ran very hot very quickly, and I set the exhaust fan to run on auto. These steps immediately began to cool down the whole computer, and maintained a relatively lower temperature.
Third, after reading that a faulty power adapter could be responsible, and realizing that I had just recently replaced mine, I tried removing the power adapter and running off the battery. The result was striking: whenever the power adapter was in use, the temperature would climb VERY high fairly quickly, but when the battery was in use, the temp would drop to significantly cooler levels.
My MacBook still runs too hot when I work it hard, probably because of faulty hardware, but it doesn't shut down anymore after I made these changes.
Puntuación 0
Try a SMC reset. Worked for me on my iMac. Just unplug the computer from the wall for 15 sec. Plug it back in and wait 5 more seconds. Then turn on the computer.
Puntuación 0
Please reset PRAM 5 times by keep pressing Command, Option, P, R hearing 5 chimes except the first regular one. That will resolve the issue. If not, come back here and let us know. We will try to resolve it.
Puntuación -1
6 comentarios:
i will try this and post my results
- de
I tried but still not working. Extranal screen is working but main display is not coming
- de
Tried this but did not hear any chime or any other reaction. What to you think of the fan control option?
- de
Ring Apple, and get them to pay for a new screen and graphic card like they did for me. The only way.
- de
try reset PRAM 5 times and problem resolve
but after few hours screen black again
any idea?
- de
Mostrar 1 comentario más
Añadir tu respuesta
dan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 80
Todo El Tiempo: 48,258
