The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Preguntas 209 Ver todo
"Contol locked" light is on. Nothing else responds.
The "control locked" red light is on and the dryer will not respond when any other button is pushed. What to do?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 12
Comentarios:
Thank you for the Control Lock reset fix! Worked great and saved me possibly a few hundred dollars on repairs! :)
por
I have a Whirlpool Duet and I had to hold the End of Cycle button for about 3 seconds. Thanks!
por
If lock light wont go off,wont reset,You Can Wash dishes! Just drive a finishing nail into lock light til it goes out. I swear you will have full wash powers, just won't lock.But, I Never knew it had a lock till it stuck. I did this,as instructed by appliance serviceman of 40yrs. It works perfectly fine and no $ outta my wallet. This is a 20 yr old washer, not saying do it on newer model Kenmore D/W.
por
I tried everything else.. I literally smashed a finishing nail into the light and my piece of crap Kenmore dishwasher came to life instantly.
Totally incredible. Thanks Rusty.. Awesome advice!!
I'm tearing down my house in 4-6 months and I did not want to install a new dishwasher, so this certainly got the job done!! :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
por
Worked for me. I did it with the power off and removed the finishing nail. I cannot understand how this could work. Lets see how long it lasts!!!!!!!!!!!
por
Mostrar 3 comentarios más
Agregar un comentario
8 Respuestas
Solución Elegida
Deborah, try this first:"
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Fue útil esta respuesta?
Calificación 18
Comentarios:
thank you, saved me a ton i was about to call a repair guy, and of course the machine says exactly what to do on it!!!
por
OMG! Thanks! I was not looking forward o calling Sears tomorrow! You Rock!
por
I tried that many times it's printed right near the button
Still won't start
por
Yeap it works! Thanks
por
it worked!!!! I can cancel the dryer appt!!! THANK YOU!!
por
Mostrar 20 comentarios más
In addition to Oldturkeys answer, try unplugging it for five minutes to allow it to reset.
Calificación 4
Comentarios:
I unplugged when all else failed still didn't work
por
I'm gonna try that now
por
I have a Kenmore Elite he3 and I have to hold the "Drain/Spin" button "AND" the main "Start (Press & Hold)" button at the same time for 3 seconds. Works every time.
Calificación 2
Comentarios:
Seriously you just saved my life!
por
Thanks!!!!!!!!!!
por
I have the HE4. I tried all of this, and they didn't work. However, I pressed and held the "Auto Dry Level" just to test other things, and it did the trick for me. Appreciate the input because I wouldn't have tried it otherwise though.
Calificación 2
Comentarios:
Thanks for that information..it worked! :)
por
Hello I have a kenmore elite h4 front loader dryer and I had been having problems on it to turn on beeping noise and light out of control beeping will not turn on til it want to what is the problem? Help
Calificación 1
I held the auto steam button for 3 seconds and it worked
Calificación 0
I've tried holding the auto dry button I've unplugged for over an hour and still won't turn off control lock please help
Calificación 0
Comentarios:
I am having the same problem. CONTROL LOCKED light is on. I've tried holding the AUTO DRY LEVEL button and nothing happens. Anyone have any other ideas??? PLEASE!?!?
por
did you fix it? is not working for me either
por
Same here. Nothing works. Did anyone get it to work?
por
It worked. Thank you so much!
Calificación 0
Añadir tu respuesta
Deborah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 98
Últimos 7 Días: 733
Últimos 30 Días: 2,981
Todo El Tiempo: 61,147
