Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Pregunta Cerrada
Changing of flash memory
Hi do you have any tutorial on changing the flash memory for nexus 7?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Tan Yong He, the memory is a BGA IC and soldered to the logic board. You can only change it if you have a reball setup, the right stencil and the right memory. Here is the information on the memory.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
is there anywhere that helps to change the flash memory?
- de
what happened that you need to change your memory?
- de
Can you give specific part number of Flash memory from that list?
- de
The chip is the Kingston KE44B-26BN/8GB 8GB flash
However, if this chip is changed will this brick the device? I.e. is the OS stored on the (removed) flash chip, or is this flash just for user files storage?
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,767
