Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2193 Ver todo
Water damaged iPhone 4s, opperating, but display is black.
I dropped my iPhone in water. Of course, now I know I should not have tried to turn it on, but then, as soon as I picked it up, I tried to turn it on, the screen flashed white, and turned off completely. I put it in rice, and Damp Rid for 24 hours, but it still didn't come on. So I plugged it in, after a few minutes I hear it make the sound when you plug it in to charge, and it made the sound of getting a text. The problem is that the display is black and will not respond to touches.
It's still under warranty, but since it's water damaged, Apple probably won't do anything about it. Although, I looked to see if the sensors had been activated. I did not see them at all, not white or red. Nothing. Maybe because I bought it from someone on Craigslist.
  • What may be the problem with it? How can I fix this? ***
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
3 comentarios:
Thanks oldturkey for your help... But since the water damage sensors didn't activate, Apple said there must be a problem with the screen (eventhough I told them what I wrote above...), and since the phone is still under thier 1yr warranty, they replaced it with a great refurbished phone! Worked out great for me, since the other phone had been dropped a lot by the previous owner, to the point the vibrate feature was so messed up, it was as loud as a ring tone... I was just lucky this time :))) Deffinately buying a lifeproof case this time!
- de
That is excellent. Great job in getting it exchanged:-)
- de
I dropped my iphone 4s in my own poop in the toilet a week ago from yesterday and I saw the screen go black and i used a blowdryer with cold air and put it in rice for a week and i can answer calls with the screen and the speaker and sounds work but my screen is black and it wont turn on so does this mean I have to get a new phone?
- de
Agregar un comentario
1 Respuesta
Angela A, couple of things I would suggest. The first thing you want to do is to clean your phone. The rice is a great first aid, but does not prevent corrosion from water retained in the littlest spots, like under SMD components etc. Use this guideto clean your phone. It was created for a 3G but all the steps are still pertinent to your phone. Of course, use these guidesto work on your phone. Make sure you pay special attention to the ends of the ribbon cables as well as the connectors. I also suggest to replace the battery with any liquid immersion experience. Once cleaned, re-evaluate your phone for any damage. If your display remains black, you may have either a short circuited display, or the coil/IC on the logic board are short circuited. Start by replacing the front display assembly, since it is the easier of the tasks, after that you may have to replace the coil and/or IC on the logic board. This will require some good soldering skills as well as tools. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Angela A estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 7,387
