tumble dryer drum turnning but no heat
i have a beko drvs-62w the drum is turning but there is no heat on any settings all help appreciated wife going mad
Es esta una buena pregunta?
william porter, based on your dryer, it looks like you are somewhere in the UK. I do remember that your household voltage is somewhere in the 240Volt range and that your appliance all run on 240V, even the motor sides. Anyhow, as for your dryer, hold the start button in for a few seconds this will reset it. Try it again and see if it will heat then. If not, you may be having trouble with your thermostat. If you have a multimeter, you can check for continuity on it. The other thing you can try is to go into service mode and reset. The way you do it on a drcs68w, so may be it'll work on yours as well. To do this, move to delicate, turn on dryer and keep pressed down cancel button for about ten seconds release then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off. It is now reset. Of course you also want to make sure that there is not obstruction on your dryer vent. Clean it out thoroughly and make sure there are not obstructions. You could try and remove everything from the vent and run it for a few minutes to see if it works. The other thing to try is to measure the heating element for continuity, to ensure it is not fractured. If you find that the heating element is at fault, it is not to expensive and readily available, most of them come with the temperature sensor installed.Hope this helps, good luck.
Fue útil esta respuesta?
Good catch! didn't think of that (UK)
I have a Beko DCU 7230 that turned but did not heat. I pressed/wiggled the reset button, lightly tapped the themostats with a screwdriver, wiggled connections, cleaned water tank, filters, condenser unit and then held the start button for a few seconds. Not sure which one was effective but it is working fine now. Thanks.
This reset mode does not work, I held the button for 10 secs then let go (no lights flashing
If this is an electric only dryer I would make sure the fuse or breaker in the main power panel hasn't blown. Remember the heaters use the 220 side and the motors use the 110 side. It could also be the heater coil inside the dryer is dead. Good luck!
I have a DCX83100W and had the same problem of everything working except no heat. One fine detail is I noticed the dryer didn't begin drying within the usual one second of pressing the Start button. Instead, it paused for maybe 8 seconds, and then began as if everything was normal. Once fixed it went back to starting almost immediately.
But in case you aren't so lucky, before I found this post (many thanks @oldturkey03 ) I tried many things and here's some detail in case it helps you track it down:
Ultimas 24 horas: 14
Ultimos 7 días: 109
Ultimos 30 días: 409
Todo El Tiempo: 80,512
3 comentarios
It's either the rear element approximately 20 pounds from eBay or the front thermostat 10 pounds from eBay.
I replaced both parts on mine and it now works. (I believe it was the front thermostat which was faulty)
There is videos on YouTube for replacement of both.
Hope this helps.
Richard
- de Richard Ward-Davies
I have a Beko DRVS 62W and first the drum stopped working so had that sorted then there was no heat so I changed the heating unit but still no heat am I missing something
- de Lyn
I have a beko condenser sensor dryer model no: DCU 7230
the dryer is turning but not heating or drying the clothes I have tried resetting it but that doesn't work can anyone help me solve this problem please
- de martinwayne36
