Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2397 Ver todo
iPhone 4 mic not working during call
Hi,
probably this question has been asked many times
here is my problem
i have an iphone 4, during incoming or outgoing call, i can hear other people, but other people can't hear me, i've tried speaker mode,same thing. have not try headphone with mic yet.
i tried to go to camera, and record a short clip, i can hear my own voice though, so it is only happening during calls.
here is what I've tested so far
i have another perfectly working iphone 4, so i began to swapping parts.
first, i swapped the motherboard only, and it seems like it is not the motherboard. because the mic problem iphone motherboard transfer to a good phone, and i can hear people and other can hear me.
and the good iphone motherboard on the bad mic iphone housing still have the mic problem.
my guess i narrowed it down to the housing.
so continued swapping the bottom speaker, bottom mic and charging port, it seems like these parts from bad iphone housing to a good iphone are working.
so it doesn't seem like problem on lower mic and charging port, lower speaker/antenna.
what else should i try?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
2 comentarios
tried replacing the dock connector?
- de
Has the phone got any type of damage before? If not then its probably because theres connection problems. Or it can be because its old. Is it old? I had the same problem before thats why im telling these advice.
- de
Agregar un comentario
11 Respuestas
Respuesta Más Útil
oldturkey is right , just change the dock connecter . your problem will be solved if this logic board is working normally in another phone . if the same dock connecter working in another phone , then try to proper reseat the charging connecter on the logic board.
Fue útil esta respuesta?
Puntuación 2
hi, had same problem with my iPhone 4 that i bought from eBay.
tried everything that did not involve opening the phone but nothing worked, just could not understand it... So after reading what jamespribil said i gave it a shot with isopropyl alcohol, gave it a nice bath for about 2 hours and cleaned it from time to time with a touth brush, to my amazement it worked... crazy but it did.
When i opened the cover on the logicboard, one thing i noticed was that there was only plastic protectors under one cover and not 2 like its suppose to be, do not know if that was what caused the problem but just glad i came here, as i was not going to do that...
Just wanted to share that it worked for me, but do not open logicboards if you do ot know what you are doing, thanks...
Puntuación 2
Hello,
You have almost done everything possible, but try doing a restore in itunes, might be your only chance if you have tried everything else. Unless of course someone else thinks of another solution.
Puntuación 1
2 comentarios:
ok
i finally got it working
but did many things at once.
i don't know which fixed the problem,
restored 5.1.1 from itune and
i went general, accessibility, hearing, and turn on hearing aid mode,
also took out the motherboard, rubbed every part with 70% alcohol, and use hair dryer on high heat, remove the EMI shield, blow the audio compiler for a short time, put a small business card paper to pad on top of the audio compiler IC.
and pad the sim card tray area on the back of the iphone.
turn it on, and it works.
i was afraid to undo and break it, so i am leaving it as it is in working condition.
i am not sure if i've misdiagnosed the problem,
but it seem like the problem might be on the motherboard, not housing.
because i have too many parts laying around at the time.
- de
Well thats good to know it's back up and running. It's best to use 100% (or close to) alcohol in stead as the rest or in your case the 30% mainly contains ingredients that can harm the board. I now always do a restore in itunes has this can fix many problems from quick battery drain to extreme slow loading and speeds.
- de
For those still referring to this post, I can suggest one more approach.
I will label everything on the faulty phone as "problem …"
IF restoring the software does not solve this issue, and software problem is excluded, I would try the following:
1/ Transfer "problem board" to known good casing.
2/ If problem is solved, then transfer "problem dock connector" to known good casing.
2/a/ If problem reappears, replace the "problem dock connector." This should solve it.
2/b/ If problem does not reappear, you might want to look at the upper mic on the "problem casing."
The upper mic is part of the iPhone 4 Power and Sensor Cable.
First try cleaning the connectors of that flat cable, and the connector on the board where this flat cable attaches. Use a proper solvent such as "contact spray" or 90%+ isopropyl alcohol. Just drop a tiny amount on a clean toothbrush and lightly brush both the cable connector and the board connector. If this does not help, try replacing the whole connector.
Additional note: on the outer frame of the phone, next to the headphones jack hole, there is a tiny "pin" hole. Make sure it is not obstructed, as this could cause issues with sound => although it should not completely suppress it.
Imagen de iPhone 4 Dock Connector
Guía
iPhone 4 Dock Connector Replacement
Dificultad:
Difícil
45 minutes - 1 hour
Imagen de iPhone 4 Power & Sensor Cable
Guía
iPhone 4 Power & Sensor Cable Replacement
Dificultad:
Difícil
1 - 2 hours
Puntuación 1
Your phone is faulty, it has a manufacturing defect that was there when you purchased the Phone. This is a hardware fault and will only get worse over time.
Request a Refund or replacement ASAP even if the phone is out of warranty. As the You Tube video Suggests a defective soldering joint comes loose over time, sometimes within warranty sometimes not.
Apple should offer immediate replacements for all users affected by this issue where the phone has been looked after as per manufacturers recommendations and not neglected by the end user.
Puntuación 0
its not any of the above. its the software you are currently running. i have the same problem on my iphone 4s theres nothing you can do about it until apple decide to release the 6.1.4 update. So no need to worry guys. its all good in the hood. chin up.
Puntuación 0
You obviously know a lot more than I do about this stuff, but this worked for me: http://youtu.be/0jhWxYTVxe4
(And it is quick and dirty ;-) )
Puntuación 0
If you are looking for the straight forward fix for the Mic related to in phone call conversation which is connected to the Dock as one unit, go to this: click here
@ that link there is a repair video and guide. Whatever works for you, you will find the repair info you need, this is the repair example of the GSM version, just look around with what you find on this guide and Google for the CDMA version...Hope This is clear and helpful, if it was offer a score point.....Cheers!
Puntuación 0
Hi,
I have the same problem with my iphone 4, mic doesn't work only during calls and it's absolutely fine with any other app. I was trying to find out what the problem could be and I realized that there are so many people that wondering about the same thing.
All I read in the forums were about:
1. hardware fault, that doesn't make sense to me cos it sounds more like software issue.If it is hardware fault then how can the same microphone work with Viber or any other app??
2.Antenna problem
3.ios 6 and latest updates
I bought my iphone second hand in a perfect condition, the microphone was working properly the first days and then it did that thing. The truth is that I did an ios update and I think that it started after that but I'm not sure.
I only have the device for 2 weeks and I don't know many things about iphones but the hole thing doesn't sound right to me.
Any suggestion except restart and reset???
Thanks
Puntuación 0
Turn on hearing aid mode in settings/ accessibility
Puntuación 0
Hi,
Did you manage to resolve the mic problem on my iPhone 4S?
I have exactly the same situation and can't resolve it!
(Can hear caller but they can't hear me)
Any suggestions (apart from the "teash can"!
Thanks,
John
Puntuación 0
Añadir tu respuesta
bronzemaxell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 60,283
