Saltar al contenido principal
Microsoft Surface RT Kick-stand Replacement
Qué necesitas
  1. Microsoft Surface RT Kick-stand Replacement, Kick-stand: paso 1, imagen 1 de 2 Microsoft Surface RT Kick-stand Replacement, Kick-stand: paso 1, imagen 2 de 2
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
Conclusión
13 personas más completaron esta guía.
Kevin Hua
Miembro Desde 01/11/13
1,612 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 17-23, Forte Winter 2013 Miembro de Cal Poly, Team 17-23, Forte Winter 2013
CPSU-FORTE-W13S17G23
5 Miembros
17 Guías creadas
12 comentarios
Where do you get the replacement kickstand from?
Ray - Contestar
is this compatible with surface pro 1 ?
arqueiro - Contestar
Do you offer a replacement kickstand for the surface rt 2?
allie - Contestar
Does this replacement kickstand come with the screws also?
Andrea Thompson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 30
Todo El Tiempo: 40,578
