Saltar al contenido principal
Generación final del Pontiac Grand Am.
Preguntas 150 Ver todo
Crank but don't start
I have a 2004 Pontiac Grand AM that cranks but does not start. We have replaced the fuel filter, fuel pump, fuel regulator, and fuel pump switch but it still does not start. Can you send me any more advise????????
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
3 comentarios:
Please help ???????
- de
After everything I had told you I was going to replace the crankshaft angle sensor and disconnected the negative on the battery after some delays I connected the battery back up and just out of curiosity tried to start the car and of all things the car started. Can you give me a opinion on why the car started.
- de
That worked for me! Just disconnected the negative on the battery for a little while and reconnected it. Thanks! 2005 Grand Am
- de
Agregar un comentario
2 Respuestas
Get your car scanned for codes first off. Always do that before replacing anything.
I'd bet though it is probably your crank angle sensor, but get it scanned first.
Fue útil esta respuesta?
Puntuación 0
u must check engines before start ur car thats very imporant ur car before on road grab some sensor battery and check on battery on your car maybe is low or high and also dont forget about the oli its may low oil if oil is empty the car won’t started
Puntuación 0
Añadir tu respuesta
Jimmy Samora estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 67
Todo El Tiempo: 4,753
