Saltar al contenido principal
La GoPro Hero5 Black es una cámara de acción resistente al agua HD lanzada por GoPro en octubre de 2016. La cámara de video con resolución de 4k tiene control de voz, pantalla táctil y WiFi incorporado.
Preguntas 85 Ver todo
Why is my GoPro Hero 5 keeps on hang, can't review the pictures?
Why is my GoPro Hero 5 keeps on hang, can't review the pictures even if I have it connect on my Phone, still displays on "Loading" only until it is batter empty.
Es esta una buena pregunta?
Puntuación 0
1 comentario
Tried to hold on ti MENU but nothing happened. If only I can send video here....
- de
Agregar un comentario
4 Respuestas
Solución Elegida
If your camera is currently frozen, try to reset the camera by holding the MODE button for 10 seconds (hold the top SHUTTER button on the HERO Session / HERO4 Session).
Should the camera not prompt a reset, remove and then reinsert the battery to get it unstuck (for cameras with integrated batteries, Step 1 will imitate a battery pull).
Make sure you have the most current software on your camera.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Hello,
I used to have the same problem and I solved by changing the micro SD card.
I had a Samsung one that was giving me lots of issues.
I hope it helps.
Regards
Ricardo
Puntuación 1
1 comentario:
Thank you! It will help. I will try your suggestion cause the sd card given to me was also Samsung. Thank you again
- de
Still, not prompt a reset. Even if its connected to phone to view the pictures easy. We need to remove the bat just to reset it or turn it off.
Puntuación 0
That sucks though. Is there some simple troubleshooting or tricks to fix this? Im sure their support will have something to say about the issue. Before buying an action camera, I make sure they have good support.
Puntuación 0
Añadir tu respuesta
Jenina Artus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 9,765
