Saltar al contenido principal
GoPro Hero LCD Screen Replacement
Qué necesitas
  1. GoPro Hero LCD Screen Replacement, Casing: paso 1, imagen 1 de 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: paso 2, imagen 1 de 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: paso 4, imagen 1 de 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: paso 5, imagen 1 de 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: paso 6, imagen 1 de 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: paso 7, imagen 1 de 2 GoPro Hero LCD Screen Replacement, LCD Screen: paso 7, imagen 2 de 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero LCD Screen Replacement: paso 8, imagen 1 de 1
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: paso 9, imagen 1 de 1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: paso 10, imagen 1 de 2 GoPro Hero LCD Screen Replacement: paso 10, imagen 2 de 2
    • Separate the LCD screen from the motherboard.
Conclusión
5 personas más completaron esta guía.
River Drake
Miembro Desde 04/02/15
1,035 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-2, Lancaster Spring 2015 Miembro de Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Miembros
18 Guías creadas
3 comentarios
Where do you buy the replacement lcd
Anthony Volatile - Contestar
I can find the screen but is it compatible with the Hero+
Brian Casado - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 35
Ultimos 30 días: 259
Todo El Tiempo: 22,838
