Saltar al contenido principal
Wood Stool Leg Glide Replacement
Qué necesitas
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: paso 1, imagen 1 de 1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: paso 2, imagen 1 de 1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: paso 3, imagen 1 de 1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: paso 4, imagen 1 de 1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: paso 5, imagen 1 de 1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: paso 6, imagen 1 de 1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: paso 7, imagen 1 de 2 Wood Stool Leg Glide Replacement: paso 7, imagen 2 de 2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Conclusión
Molly Ristig
Miembro Desde 10/07/19
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 391
