Saltar al contenido principal
Window Operator Link Replacement
Qué necesitas
  1. Window Operator Link Replacement, Link: paso 1, imagen 1 de 2 Window Operator Link Replacement, Link: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 4 mm Screwdriver
    $5.49
    Comprar
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: paso 2, imagen 1 de 3 Window Operator Link Replacement: paso 2, imagen 2 de 3 Window Operator Link Replacement: paso 2, imagen 3 de 3
    Large Needle Nose Pliers
    Comprar
  3. Window Operator Link Replacement: paso 3, imagen 1 de 3 Window Operator Link Replacement: paso 3, imagen 2 de 3 Window Operator Link Replacement: paso 3, imagen 3 de 3
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: paso 4, imagen 1 de 3 Window Operator Link Replacement: paso 4, imagen 2 de 3 Window Operator Link Replacement: paso 4, imagen 3 de 3
    Metal Spudger
    $2.99
    Comprar
  5. Window Operator Link Replacement: paso 5, imagen 1 de 3 Window Operator Link Replacement: paso 5, imagen 2 de 3 Window Operator Link Replacement: paso 5, imagen 3 de 3
    Comprar
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
Conclusión
To reassemble your device, follow from step three (3) to one (1) in reverse order.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 60
Todo El Tiempo: 839
