Saltar al contenido principal
Whirlpool WGD4800XQ Thermal Fuse Replacement
Qué necesitas
  1. Whirlpool WGD4800XQ Thermal Fuse Replacement, Thermal Fuse: paso 1, imagen 1 de 1
    • Unplug the dryer from the power outlet.
  2. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 2, imagen 1 de 2 Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 2, imagen 2 de 2
    • Unscrew the backplate by rotating each screw counterclockwise with a ratchet and 8mm socket.
    • The screws are located around the edges of the backplate.
    • The backplate is a heavy object. Hold the backplate while removing the screws or get assistance. Dropping the backplate can cause injury or break the gas pipe.
  3. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 3, imagen 1 de 1
    • Lift the backplate off of the dryer.
  4. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 4, imagen 1 de 1
    • Pull out the blue terminal cables on the thermal fuse with a needle nose plier.
    • Keep track of what terminal fuse goes on top and bottom.
  5. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 5, imagen 1 de 1
    • Remove the screw from the thermal fuse with the ratchet and 8mm socket.
  6. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 6, imagen 1 de 1
    • Place the new thermal fuse and secure the screw with the ratchet and 8 mm socket.
  7. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 7, imagen 1 de 1
    • Insert the blue terminal cables to the thermal fuse with a needle nose plier.
  8. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 8, imagen 1 de 2 Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 8, imagen 2 de 2
    • Put the back plate on the dryer.
    • If possible, have someone hold it up to align all the holes on the backplate and dryer while you use the ratchet and 8 mm socket to replace the screws.
  9. Whirlpool WGD4800XQ Thermal Fuse Replacement: paso 9, imagen 1 de 1
    • Connect the dryer to the power outlet.
Linea de Meta
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 77
Todo El Tiempo: 411
