Saltar al contenido principal
Volkswagen New Beetle Headlight Bulb Replacement
Qué necesitas
  1. Volkswagen New Beetle Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 1 de 3 Volkswagen New Beetle Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 2 de 3 Volkswagen New Beetle Headlight Bulb Replacement, Headlight Bulb: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Before you decide to change a burnt-out bulb, make sure it's not the blown fuse that keeps you in the dark. You will need to open the fuse block cover that is located on the left hand side of the dashboard. Use a thin flat object, such as a flat head screwdriver or a key to pop open the cover.
    • Under the cover you will see a number of multicoloured fuses.
    • Use the reference card and the white plastic tweezers attached to the back of the fuse cover to locate and pull out fuses responsible for headlight bulbs. Fuses 18 and 19 are for high beam bulbs; 20 and 21 - for low beam; 22 and 23 - for parking lights. Pull fuses one by one so as not to mix them up.
    • Fuse body is semi-transparent. Look at it from the side to see if the fuse is good.
  2. Volkswagen New Beetle Headlight Bulb Replacement: paso 2, imagen 1 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 2, imagen 2 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 2, imagen 3 de 3
    • You have verified that all fuses are OK, and it must be the bulb that has burned out. To replace a bulb you will need to remove the entire headlight assembly by sliding it out of its housing in the fender.
    • First, unlock the hood by pulling the handle located on the left hand side of the driver's foot well.
    • Then open the hood by pulling the plastic tab toward you and lifting the hood.
    • The headlight assembly on the passenger side can be easily found, while on the driver side it hides beneath the battery. It may be useful to remove the battery cover - this will provide a little more 'viewing' and a bit more 'maneuvering'.
  3. Volkswagen New Beetle Headlight Bulb Replacement: paso 3, imagen 1 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 3, imagen 2 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 3, imagen 3 de 3
    • To remove the headlight assembly, first use the 5mm nut driver to turn the locking nut 1/4* of a turn in the indicated direction. On the passenger side the nut is clearly visible; turn it clockwise.
    • On the driver side you will need to reach between the battery and the car body, using a nut driver with a long handle, to turn the nut counterclockwise.
    • * Try not to turn the locking nut more than 1/4 turn. Doing so may rotate it back into a locking position.
  4. Volkswagen New Beetle Headlight Bulb Replacement: paso 4, imagen 1 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 4, imagen 2 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 4, imagen 3 de 3
    • Once the headlight assembly is unlocked, press down on the bright locking lever - it is visible when looking straight down from above the headlight.
    • On the driver side only a portion of the locking lever is visible between the battery and the air box, but you can still reach it with a screwdriver that has a long handle.
    • While pressing down on the locking lever, push the headlight assembly forward and out of its housing. Careful - it may take a hard push and it might lurch out suddenly.
  5. Volkswagen New Beetle Headlight Bulb Replacement: paso 5, imagen 1 de 2 Volkswagen New Beetle Headlight Bulb Replacement: paso 5, imagen 2 de 2
    • Locate the bulb cover at the back of the assembly. Unclip and open the cover to expose bulbs.
    • Remove the electrical connector and pull out the bulb that you want to replace. The low beam bulb is held in place with a clip. Other bulbs are held by friction; use pliers to gently pull them out.
    • Put in the replacement bulb and reattach the connector. Do not touch the bulb glass with your bare hands -- oils from your fingers will remain on the glass and cause it to crack when it heats after turning the lights on.
    • Replace the bulb cover.
  6. Volkswagen New Beetle Headlight Bulb Replacement: paso 6, imagen 1 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 6, imagen 2 de 3 Volkswagen New Beetle Headlight Bulb Replacement: paso 6, imagen 3 de 3
    • When inserting the headlight assembly back into the housing, make sure that the housing locator guides fit into the catches on both sides of the assembly.
    • Push the assembly into the housing until you hear it click into place.
    • Again use the 5mm nut driver to turn the locking nut that locks the assembly in its housing.
    • Turn on the ignition and check that the new bulb works. Close the hood.
Conclusión
After the reassembly, make sure you turn the locking mechanism in the indicated direction to lock the headlight assembly in place, otherwise there may be poor electrical contact and the lights may not work.
55 personas más completaron esta guía.
Nick Ivanov
Miembro Desde 10/09/11
2,263 Reputación
3 Guías creadas
31 comentarios
Thanks so much for that photo of the lever itself. Wish I'd seen your photo first -- would have saved 30 minutes of cursing :)
mp4surf - Contestar
First part of step 6 is ESSENTIAL. Be warned that the assembly will slip easily into position without the locator guides being inside the catches on the unit, and the locking lever will click into place, but the locking nut will not tighten it into position. Don't ask me how many times I repeated this before I did it properly because I will lie!
Fred Flintstone - Contestar
I never heard a "click"; however, I lock the hex nut ok. So the light works but seems like the car hits a bump and the light jumps out of the connector enough to stop working. Any thoughts?
juliejanus -
Extremely helpful. NOBODY would ever figure this out on their own!! Thanks!!
David - Contestar
Seriously! Im an engineer and I was fighting with the headlight wondering why I couldn't loosen the latch to get it out. I apparently turned it more than 1/4. I feel like this was a bad design...
Marcy -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 37
Ultimos 7 días: 176
Ultimos 30 días: 617
Todo El Tiempo: 216,501
